playmofire
Another repair triumph, Mick. Well done!
Fingers crossed!
Well, I nearly completed another little project yesterday. This was the previously repaired blue Big Hauler. I had bought it because I wanted a B&O Royal Blue - I had bid on it but was (apparently) "sniped" at the last few seconds. So I thought I'd give it an I.D. change - courtesy of Matt Vinyl.
The above was printed on glossy photopaper just to see if it would look OK. It took me ages to find the right typeface although I couldn't find the correct one for the serrifs on the B&O. The Royal Blue Line is Vivaldi.
As purchased and repaired .......
...... and as it is now.....
The rivetts on the tender do stick out quite a lot but I didn't want to overdo things in case I got a loco in the correct (as in Bachmann's correct) livery. The rear of the tender needs a sticker and the 833 on the light needs altering to 1332 (Correction pen and water based black ink fine pen).
So I ran it around a few times before putting it away for the winter! ....
Plenty of other projects to complete as long as it doesn't get too cold in the shed.
Fingers crossed!
So, having waited (and waited) for days to test it out I finally got the Round Tu-it today! No problems - wheels stayed in place whilst I ran a few trips around....
I had looked at taking a front wheelset from a spare chassis. I did take it out but there were major differences - for one thing it was a solid axle with insulated wheel centres and it had no bearings! The axle just ran in the plastic! If the present repair fails then I will saw off the stub axles and bore out the wheel centres and make a solid axle to suit the brass bearings!
If you're still stuck ('scuse the pun) I might have an ex_Buddy L axle that has remarkable similarities - although I haven't actually checked the diameterSo, having waited (and waited) for days to test it out I finally got the Round Tu-it today! No problems - wheels stayed in place whilst I ran a few trips around....
Phew! I read the first sentence as 'tidying up wedding'. Battling the undergrowth seems a far more rewarding and successful enterprise.
I recently cleared ten years' growth of ivy on one of my raised beds for similar reasons. 'Triffid' came to mind while I was doing it. You seem to have been a lot more successful than my efforts, Mick.
Rik
If you're still stuck ('scuse the pun) I might have an ex_Buddy L axle that has remarkable similarities - although I haven't actually checked the diameter![]()
Eliminate?Weeds have beeb pulled up where possible but I need to make a long-term solution - particularly to eliminate the dandelions!
