trammayo
So the brackets and footboards are glue in position and they received a coat of matt black brush-on paint...
The footboards - ex hardwood window frames were a bit of a pig to cut down to the correct width of 10mm and sanding was even worse. Next job (if I get time before Sunday) will be to make up a couple of vacuum brake pipes. The headstocks have been cut away (previously) to allow for bogie mounted couplings - so I'll have to improvise again - not much space left to mount the pipes.
