Lead would certainly be the longest lasting thus less maintenance option.And a little bit more ......
I forgot there needed to be a walkway from the doorway I've yet to construct!
The "fence", constructed partly with matchsticks, is from the original building and just needs a repaint!
Since taking the pics I've sanded the board ends and treated the timber. So, door and frame to make today, and then it will be time to consider the roof. I'm having second thoughts about what I will clad the roof with - maybe shingles, maybe a coat of bitumen, maybe some bitumen tape (to represent roofing felt), and maybe re-use the lead from the original building!
View attachment 293131View attachment 293132
I was going to use the lead guttering (dress it with a tapered roof edge for the shingles) and my further thoughts are that it would add weight to the building and stop it being blown away. Still thinking!
Have you though about UV glue? Comes out of a small tube and fills quite nicely, clear when applied and set (by the UV lamp) to be painted over happily.Yesterday I did a little bit more ......
I glued the door and frame in position. To make things more secure I pinned the door and window frames using veneer pins (again drilling 1mm dia holes and shortening the 15mm veneer pins). I also glued/filled a vertical gap I accindentally created. Since these pics were taken I have painted the mess to try and blend in. I have the opposite gable end windows to pin (today) and then it will be another coat of paint.
View attachment 293204View attachment 293205
So there it is - warts and all. I still need to find a suitable filler to seal up the gaps around the windows (and door). Don't want anything too messy to apply!
H'mm - I have one of those somewhere! I tried some Gorilla glue this morning and left it to set for a couple of hours. When I went out, I wasn't impressed ......Have you though about UV glue? Comes out of a small tube and fills quite nicely, clear when applied and set (by the UV lamp) to be painted over happily.
Thank you!Lots of good photos, Mick, but the one on 23rd November is superb.
Mick, is that a hand-made crossing (bespoke?) on the track that goes under the trestle?Back to some pics of trains running......
23rd of November. 2021
28th ...
30th....
December 12th, 2021.....
12th...View attachment 294673
...... and more to follow!
Yes it is. When I first started building the line it was a triangular junction and mainly single track. I had the idea of making it a tramway but then I doubled the track, discovered the Bachmann Big Haulers, and the rest is history!Mick, is that a hand-made crossing (bespoke?) on the track that goes under the trestle?
