playmofire
Repainting looks great, Mick. All you have to do now is repaint the rest to match.
Sounds like a load of old balesNow I have to pull the trailer out of the barn because I have to bring the hay in this afternoon (only forty bales - but my little trailer can only take twenty at a time!)
I'll give the rest of it a wash and polish!Repainting looks great, Mick. All you have to do now is repaint the rest to match.
No - just animal husbandry!Sounds like a load of old bales![]()
Just a thought, have you thought about some simplification of your line using R2 curves only and perhaps single line only? Ok maybe less fun but on the basis of less to maintain and clean less can sometimes be more. You do have a lot on your plate with helping others, livestock etc.Back into to the shed for some R1 curves and then laid them out ......
There really isn't much room other than for an R1 loop. So now I have two options; rebuild the R2 loop or go for the R1. I know which I prefer even if nearly all my stock will negotiate the R1s.
It was the plywood that rotted away even though I'd used torch-on felt to cover it. My thoughts are that I can make a new 'deck' out of Upvc material (which would see me out) with metal supports to hold everything together.
There are a number of trees blown down into the stream, so they need removing as a matter of course (but I will need my son's help when he comes over in two months time) but the timber (mainly around 5" diameter) won't get in my way doing a new loop. Meanwhile I have other things to do, so I'll put the R1's away and tidy up a little for now. Too much MS Word stuff to fight with at the momen!
I've already rebuilt the 'straight' double track and if I converted it to single I would have polarity problems. Simple, for me, is to be able to set a train off and let it run! My main problem, with rotting wood, was using recycled timber that was not pressure treated and, of course it came back to haunt me! I'll get it right this time I hope!Just a thought, have you thought about some simplification of your line using R2 curves only and perhaps single line only? Ok maybe less fun but on the basis of less to maintain and clean less can sometimes be more. You do have a lot on your plate with helping others, livestock etc.
How long has it been out there?I've already rebuilt the 'straight' double track and if I converted it to single I would have polarity problems. Simple, for me, is to be able to set a train off and let it run! My main problem, with rotting wood, was using recycled timber that was not pressure treated and, of course it came back to haunt me! I'll get it right this time I hope!
That particular location - just over 11 years!How long has it been out there?
Well it lasted pretty well then! If that was just standard wood, howling would pressure treated wod last? And TBH, how many of us don't change or alter their layouts every few years anyway?That particular location - just over 11 years!
So I have some sections with pressure treated wood Gravel boards made into U shapes using 2 per length, 1 is cut in half to make the support. These were made by a friend in Hemel, he had them out for probably 5-10 years. Then they were on my line at Hemel 2000-2012 then put in here 2013-date and still going strong. They do have roofing felt on top which helps preserve them. At no time have they been touching the ground always being at least a foot or more above ground.Well it lasted pretty well then! If that was just standard wood, howling would pressure treated wod last? And TBH, how many of us don't change or alter their layouts every few years anyway?
I used tanalised wood in my aviary, and in places where the wood was constantly wet for half the year e.g. on the ground, 10 years was the best I could get before having to replace it, though with an aviary you need to keep the maintenance up or risk loosing birds.Well it lasted pretty well then! If that was just standard wood, howling would pressure treated wod last? And TBH, how many of us don't change or alter their layouts every few years anyway?
