Beddhist
Motorcycle travel, trains
		I was all fired up with the idea of making a hidden loop under the deck. Here is the AWACS wagon in front of it:
The concrete in front of the deck is already broken in a convenient place, so it looks not difficult to remove a small section of it:
But one look under the deck shows that it`s almost impossible:
That structural beam at the far end of the pic would have to be cut. This would require another foundation post or two. This is beyond my DIY skills.
Then another thought occurred to me: marauding sheep!  ???  Every spring groups of lambs escape from our neighbours farm and invade our gardens. My railway would have to withstand them walking on it. That applies to the deck, too. Elevated it will have to be.
		 I would try to straighten those turnouts up. If you are screwing them onto solid (in this case, wood), then you can straighten them up as you lay them.... temporarily tack a straight piece of timber to your base, on the line of the outside of the sleepers, and pull the turnouts up hard against this as you screw them down.
 Problem easily solved by putting up some security lights.
		 Of course, for an extra tank of gas in the moped, you could come to Wellington to see how things are really done!
