viaEstrecha
A yellow tube of glue?
Now that is a workshop! Obviously not in any way jealous.......The building is impressive tooView attachment 321466View attachment 321467The Harry Potter castle build, so far.....
Nice work, I am very interested in how you have managed the curved tower bit?View attachment 321466View attachment 321467The Harry Potter castle build, so far.....
Yeah, just think how untidy you could be in something like thatNow that is a workshop! Obviously not in any way jealous.......The building is impressive too
To be fair...
Dan has just had new flooring laid, so not really had time to make it look 'lived-in' yet.
There is a little more space to spread out, in the US.
I would guess he marvelled at how we managed, in our quaint little hovels, over here?
I especially like the window on the world outside. - It does look a nice environment to make a mess in and be creative?
Then there is his railway upstairs.
To be fair...
A hot chisel pushed into the plastic? Just a thought, I've not tried itHowever, the PVC pipe is hard, so I am working out a way to create the vertical joints on the tower. My brain hasn't worked it out quite yet.
Among my tools, I have a cold chisel, but I have never heard of a hot chisel before, I don't want to start a heated debate.A hot chisel pushed into the plastic? Just a thought, I've not tried it
Hot chisel, as the name suggests is used by blacksmiths doing forge work:Among my tools, I have a cold chisel, but I have never heard of a hot chisel before, I don't want to start a heated debate.
Oke you are high school with your table saw, but you havent figure out yet for the pvc pipe?The curved tower is a section of 3" PVC schedule 40 pipe. To get the horizontal mortar joints, I set the blade on my table saw to about 1/16" above the table. Using the rip guide and crosscut sled in conjunction, I rotated the pipe over the spinning blade. As each joint was finished, I moved the rip guide 1/2", creating a 12" high stone in G scale. The vertical joints are only pencil marks at this point.
I created the horizontal joints on the walls in much the same manner. The vertical joints I made using a cold chisel and hammer. Since the PVC sheet goods are soft, the cold chisel method worked well. However, the PVC pipe is hard, so I am working out a way to create the vertical joints on the tower. My brain hasn't worked it out quite yet.
Make some jigs.
Put a sheet of wood on top of your table saw, and fix it steady. push/turn your sawblade higher and higher till you have a decent slot.
Make two pieces of wood or also with plywood of 10x10cm/4x4 inch.
Cut a hole in the centre on the diameter of your pipe.
Fix the whole jig again on your table saw.
Adjust the hight of your blade and run the pvc pipe thru.
Or if you have a jig saw, make that one into a table.
Ill hope you understand what i tried to explane
Dremel? router? small endmill in a standing drill?
Wood chisel and a small stroke with a hamer?
With kind regards Igor
As your designs work, it may be the basis for a plans book to publishwill add these to my binder of drawings made over many years. maybe someone in the future will appreciate them.....![]()
