Roof done, good job we didn't need to put any washing out! now on with fix the guards duckets.
Not exactly the workbench but out on the layout bench.
I have started ballasting and adding "grass" to the Cane Line.
I put the trial piece out in the weather in the middle of last year (2021) to see how it would standup after sun rain heat and cold it has not deteriorated at all.
The ballast is 7mm blue metal a type of rock used in concrete and by the fill size railways.
To hold it together I used 50/50 outdoor PVA and water with a few drops of washing up liquid as a wetting agent.
I sprayed the glue on which left holes between the ballast for water drainage, the ballast sits on shade cloth to stop it falling through the holes in the cable tray base.
Ballast Trial
Completed section of track
Ballast Trial
Grass is growing well :p:p
Roof painted and duckets finished.
For sometime I have struggled getting my "Annie" to the railway and back, especially as I like to keep it coupled. So along comes the basic carry device, a piece of wood with two tracks routered out 45 mm apart, note the two hole on the centre line was for a piece of wood to be screwed underneath to hold the item in place whilst at work with the router.
The next job is to be able to "drive" Annie" off and on the carrier. Enter a short length of Bachmann plastic track. Two small indents to hold the track on the carrier (above on the left), and some tapering of the track.
This meant loosing sleepers and the tracks parting. So when the wheels transition of the plastic track plasticard supports the flanges, and the narrower plasticard in the centre (40 mm wide) keep the wheels on track until the wheels are firmly on the railway.
The nest issue was to hold this transition track in place, and ideally I would have fixed it to the carrier, but opted to use the rail-track to hold it in place, so a small block to fit between the sleepers was glued underneath.
A Trial run, a few bench tests had been carried out, but now for the real test, notice my new supervisor.
Does it work!!!
It was run (battery power) off and on a couple of times, carried out slowly but a great success, even ran it on forwards without issue.
One last thing (for now) don't want it running off the end.
Just need to manufacture the carry handles.
Does it work!!!
A very well thought out idea. Coincidentally, there has just been a discussion on router produced "tracks" on the HRCA forum.
I wouldn't like to tangle with your new superior.
Neatly done as ever Jimmy, yes the supervisor looks like he is saying “what do you think you are doing on my walkway”?
At this moment I am as ever in the midst of a few jobs. Having completed my Kamel Batteries the other day I thought I would get on with the Combino Tram again, but changed my mind to attacking the Swift16 Railcar batterysoundification. This has resulted in some serious hacking to stuff bits in place. Seen here on the workbench, orders in for some more bits to get this moving forwards.
Love it! Coincidentally, I've been facing the exact same issue this week and had resorted to a temporary solution of 2ft of track on a piece of laminate, but I can see that being converted to your clever solution in due course :)
Not so much the workbench, but testing non the less. fitted the chopper coupling last night and with the aid of a few washers settled on the ride height, so out side, set fire to a loco and see what happens, strangely, nothing, no derailments, no uncoupling...... I must have done something wrong :think: :giggle:
anyway the pics.
Just noticed in the first pic, the wood base that comes with Accucraft locos JimmyB ;)
anyway the pics.
Those DJB bogies run like a dream; with a 'small F' and half-brake you have the makings of almost every train that ever ran on the IOM!
Another box car started,bachmann chassis and trucks with a custom body,the build so far,IMG_20220103_050534.jpg
