What have you been printing.
I like that... I had decided it would be good for grapes, before I read the image title..
Very nice! Assuming a resin print and some weathering to give the relief?
Hi, yes you are right, it is made of resin, printed with anycubic photon. Painted with gray hobby acrylic paint, and aged with pigments. CLICK
Wanted waste pipes and guttering, for my buildings ,which normally I make individually, but given that I have a entire village to build , a set of pre formed parts ie doors ,windows ,gutters and waste pipes ,will make it easier..I think..20210317_190038.jpg
itsmcgee itsmcgee .. The quality of those resin prints is stunning.. well done!
I have been progressing "ok" in comparison with my powered 3d printed LGB decoupler.. Your print quality makes my home build FDM (based on a shapeoko router) look very crude..!
The initial PCB's arrived a week ago and after soldering on the SMD processor and driver IC's (and fortunately getting the answer right to "Which way round do they go??") .. I have now programmed a couple for testing.
I have assembled this one with the ICP still attached, so that I can tweak the software, but in a "final" version the side of the enclosure is closed and you cannot see the board.
Good thing is that I can report that the the tiny linear stepper gear can produce about 8oz thrust (I am metric but my spring gauge is older!) and takes about 300mA from 5V when working. This enough to break the pull of the "magnetic" hook spring closure and push both its own hook and any attached hook down - provided they do not get stuck on the internal "lip".. But the "decoupling waltz" should take care of that.
Cheers
Dagnall
Hey all. I've been looking for a 1:20 engineer. Left arm on the sill. It's for a small box motor. I use an Ender 3 pro. If I'm in the wrong thread, sorry!
The weekend's handicrafts.
A water tower under construction. The idea came from here: CLICK . The parts were made in my 3D printer. Now they have to be cleaned up a bit and adapted to each other. the roof is also missing.
I will report how it goes on ... .
IMG_20210412_071425.jpgIMG_20210412_071448.jpgIMG_20210412_071328.jpgIMG_20210412_071609.jpgIMG_20210412_072231.jpgIMG_20210412_071616.jpgIMG_20210412_072237.jpgIMG_20210412_071730.jpg
View attachment 283673View attachment 283674View attachment 283672View attachment 283675View attachment 283678View attachment 283676View attachment 283679View attachment 283677
Nice!
Will you be making the designs available, as I would quite like to print something similar for my railway.
In terms of the roof, maybe plasticard with some additional riveted joining plate detail?
I have stored the STL files in the "Resources". If you are interested, I can also provide the AutoCad Inventor files.
Thank you, I have downloaded. Did you print this in resin or FDM? If FDM, the quality looks excellent! I think I would need to print in resin to get that level of quality.
hi,
you are right, i printed it in resin. I use a Anycubic photon. That is also the reason why there are so many parts. The print bed is not very large (11x6.5x16 cm).
I guessed as much!! I have the Elegoo Mars, which is a similar print size.
