Woodlock Logging
Horrible job today. Always thought I could manage with 2 sets of hand points, but I finally took the plunge and bought a Switch Decoder and 2 motors. All points are now finally wired. The hardest part was hiding the wires, I hate visible messy wires. One of the points is on the turning circle and very inaccessible for a 17st chubby like me. The turning circle can now be used both directions. IMG_20220528_144822.jpgIMG_20220528_144832.jpgIMG_20220528_144839.jpgIMG_20220528_144905.jpgIMG_20220528_145137.jpgIMG_20220528_152528.jpgIMG_20220528_152546.jpgIMG_20220528_154619.jpgIMG_20220528_154626.jpgIMG_20220528_154630.jpgIMG_20220528_154633.jpgIMG_20220528_154636.jpgIMG_20220528_162758.jpgIMG_20220528_162811.jpgIMG_20220528_162904.jpg
Just trying to think about Bluetooth, fine if you use dcc and can use the track to power the point motors.
If you use DCC and don’t have many points or you have points that are a distance away from each other then single channel decoders can be a good option. Two short wires to point motor, two short wires to get power from track; no lengthy runs of wires.
Horrible job today. Always thought I could manage with 2 sets of hand points, but I finally took the plunge and bought a Switch Decoder and 2 motors. All points are now finally wired. The hardest part was hiding the wires, I hate visible messy wires. One of the points is on the turning circle and very inaccessible for a 17st chubby like me. The turning circle can now be used both directions. View attachment 299288View attachment 299289View attachment 299290View attachment 299291View attachment 299292View attachment 299293View attachment 299294View attachment 299295View attachment 299296View attachment 299297View attachment 299298View attachment 299299View attachment 299300View attachment 299301View attachment 299302
Wire is so much easier to hide if it is Black. Run you lines in plastic as they are then the last bit of tricky to hide join to black wire, soldered, cleaned of flux and black heat shrink them.
I did consider one of those, but then saw the price compared to a 4 channel one....
Yep, good point (not intentional, sorry!). With the two points in your pic I’d also have gone for a 4 channel decoder.
I know you’ve laid your cables now, but maybe a thought for the future - I used brown sheathing of the type electricians slip onto mains wiring to show a live cable to cover the wires to my point motors where they are exposed. Apart from hiding the brightly coloured wires to/from the motor (I need this to help me remember which wire goes where, so using all black wires wouldn’t work for me), in my mind it resembles the thick cables one often sees alongside the track/point work on a real railway.
I agree that using black wires can give you issues with remembering things, I laid out a friends line and had the same issue. To overcome it I cut short lengths of colored striped mains insulation (2-3mm) threaded it on the black wire in various recorded combinations with some black heat shrink pre put on before my ‘reminders’ to cover them when all working.
Orederd some dolls house topiary plants last week and here they are. Every station on my network has some now, just for that corporate image..... IMG_20220601_122306.jpgIMG_20220601_122320.jpg
I have used some my self, always TRY to get 1:24, but it seems 1:12 are prevalent, and some seem overly large :)
I did think that, I suppose its a good job plants and pots come in all sorts of different sizes. These are those massive ones you see in a shopping centre ;)
On test after a wire came loose from the front bogie.
IMG_20220603_124341.jpgIMG_20220603_124455.jpgIMG_20220603_124559.jpgIMG_20220603_124616.jpgIMG_20220603_124716.jpgIMG_20220603_124815.jpg
And the wire came off again. Hate this locomotive.
Was it the small plug into the pin? If so a gentle press with pliers may help. If not that possibly extending the wires to the bogies may help.
