Rhinochugger
Retired Oik
I was thinking more of the staffHave you seen, some of their customers?![]()
Worth a try.Having come across engineering problems that have "stumped" me, suddenly it falls in to place and in your case you will wonder why you could not undo it.
A thought, though you may tried it is earlier, with whatever you are using to turn the dome apply turning pressure, then try tapping the dome with a small hammer (at thread height), this may take 2 people, or you may have a way of securing the loco whilst doing this.
Nah, trick I learnt in the armyTaps while torquing with the strap wrench would be great, you DO have 3 hands right ha ha!
(I know this would be very tough to execute)
I was going to say, leave me yer Porsche, but as it's got brown spots on it, I'm not so sureGreg, I'm VERY loathe to put a potentially explosive petroleum-based fluid into the boiler, I'm certain that you understand why. However, given that I'd be able to flush it out afterwards as many times as was necessary, I'll give it a go.
I'll give you the address of the ward in the local hospital if it all goes t*ts-up, 'kay?
TBH, it sound like one of those 'here, hold my beer' moments.............................
So, I take it that my suggestion to put it in the boiler and invert the boiler to ensure the threads get wet was never tried?
Also, filling the dome, would NEVER have engaged the threads..
I did point this out numerous times, and maybe it will finally be tried.... clearly a wash with solvent, the alcohol, and then water will rinse out the boiler afterwards, just like preparing an automotive gas tank for welding.
OK, I do hope that you actually try what I suggested many times, as it is CLEAR that putting penetrant in the dome can NEVER reach the threads.
no more luck with the strap?
tapping with rawhide mallet?
I'd figure the dang thing would give up by now.
Sorry you are going through this, thanks for the explicit comeback.
Surely there is a safety valve in the boiler, so filling the boiler upside down won't get the fluid in to the threads. Filling the dome from the top with the loco right-side up will access the threads. What am I missing here?![]()
Does it make sense to put in the boiler and leave the boiler upside down?
Then the penetrant could collect in the saddle, which should be surrounding the threads...
Just thinking that putting any liquids in the dome would just never touch the threads at all...
Tac, that's the kind of approach I use. Cutting a slot across the top might also give you enough grip to turn it with a rod or flat piece of steel.Tomorrow will see the serious bit of drilling an access hole clear through the dome, above the level of the safety valve, to put a silver steel rod though it to get some better purchase.
Brother, if you were here or I was there, I'd be giving you all the help I could.Greg, I'd be obliged if you could lend me your rawhide mallet...![]()
