Greg Elmassian
Guest
Don't let your wife see the Dyson blow dryer, $400
MikeI had some black plasticard to hand Dan, and thought I'd try them..its was far easier to do to be honest..although more expensive at £1.50 per sheet..x 4..for plasticard, plus its not a lover of superglue, yes I know should use the plastic weild...but I'm not fast enough with plastic weird.. its bloody evaporated before I can get it on the joint!@
I thought plastic weld worked by capillary actionI had some black plasticard to hand Dan, and thought I'd try them..its was far easier to do to be honest..although more expensive at £1.50 per sheet..x 4..for plasticard, plus its not a lover of superglue, yes I know should use the plastic weild...but I'm not fast enough with plastic weird.. its bloody evaporated before I can get it on the joint!@
Sorry David, that too k a while to sink inThat sucks.
Or soak in.Sorry David, that too k a while to sink in
I tend to be a bit quick on putting the cap on but still do a fair bit of work before I need to, I would have thought that your super glue tack on followed by a wash the length if each row of tiles ought to be fine to leave the cap off. But you know your limitations better than we do.The problem I have is the bottles got a child proff cap..and my fingers are not working as they should, (incase you don't know I have C.M.T,Type 1a, it affects the nerves,muscle ect in the hands and feet) so I have lots a lot of manule dexterity in my fingers, opening the bottle , getting the brush in..with out knocking the bottle over, and getting the liquid to the plasticard, before it evaporates, is ni on impossible..you carnt leave it open..it evaporated and I have to put the cap back on losesly..even so its evaporated before I can use it...trust me, I've tried..other than poring the bottle over the joint..my fingers don't work fast enough..
Plastic solvent weld is designed to be run along a joint once it's in place - so probably not the easiest to use on something like roof tiles.I had some black plasticard to hand Dan, and thought I'd try them..its was far easier to do to be honest..although more expensive at £1.50 per sheet..x 4..for plasticard, plus its not a lover of superglue, yes I know should use the plastic weild...but I'm not fast enough with plastic weird.. its bloody evaporated before I can get it on the joint!@
Be careful with what plastic pipettes or syringes you use, the glue may dissolve them!mike
(Suffer severe Arthritis in both hands) this may sound like off the wall, sometimes outside the box thinking, for using liquids I have had to resort to other methodologies, have you tried using these for large areas?
0.5ml Plastic Pasteur Pipette Liquid Dropper Clear Mini Pipettes Lab Eye Straw | eBay
Plastic Pasteur Pipettes. Get great value with our high quality plastic pipettes. Choose between 1 individual dropper, 10, 20, 50, 100, 250 or 500.www.ebay.co.uk
I use these (or similar) and they are polythene, neither solvent or resin dissolves them.Be careful with what plastic pipettes or syringes you use, the glue may dissolve them!
I use glass medicine droppersBe careful with what plastic pipettes or syringes you use, the glue may dissolve them!
It shouldn't happen, as the vacuum above the liquid should prevent the liquid leaving the device, i.e. the weight of the liquid cannot overcome the suction of the vacuum. For low viscosity liquids (thin solvents) this should be still true unless the SG is well over 1.5, most solvents are below 1, and as such lighter than water and the vacuum should be more effective. Unless of course, you are using very cheap pipettes.I find that MEK and the thin solvent weld drip for normal pipettes / droppers, it's just too thin and runny.
