If you don't get the long root out they will sprout again, if getting to the root is problematic, then a strong weed killer may be the only solution. I dig out all my dandelions in both the railway and garden, and after 10 years they still appear, but in very few numbers.
Yes they do seem to grow where nothing else will. I do have weedkillers but I'm worried about the moggies!It always surprises me how dandelions can manage to take root in places where nothing else wants to grow. If you wanted something else to grow there, it would probably wither and die. A squirt of Weedol will soon sort them out.
Rik
?????The main problem is that the worst affected areas used to be single track. When I doubled it, I just put a thin layer of concrete next to the original for the new track. The seeds found their way down the joint between the two foundations. I do have a root remover tool but that only works in soil.
The cats, Dan.?????
Yep!Pretty well most weeds, especially in their early stages, hate boiling water. That was a tip from a radio professional gardener and it works pretty well.
The trick is getting the boiling water from the stove to the lawn.....Pretty well most weeds, especially in their early stages, hate boiling water. That was a tip from a radio professional gardener and it works pretty well.
Last year, I plugged a kettle in the porch so it wasn't too bad - but the dandys seem to survive almost everything (must be in their DNA). Funny though - I used to like Dandelions (as in Dandelion and Burdock pop)!The trick is getting the boiling water from the stove to the lawn..........The best way I know is to fill a thermos and shlep back and forth between the stove and yard. Otherwise, its surprising how quickly boiling water cools and you're simply watering the weeds.....
Have you not thought of spraying the track with some of your excellent Irish whiskey, that way the weeds will come up half cut.Last year, I plugged a kettle in the porch so it wasn't too bad - but the dandys seem to survive almost everything (must be in their DNA). Funny though - I used to like Dandelions (as in Dandelion and Burdock pop)!
I've even thought of using a syringe to adminster the weed killer into the roots.
Nah, just drink the whiskey, and then you won't worry about the weeds.Have you not thought of spraying the track with some of your excellent Irish whiskey, that way the weeds will come up half cut.
Nah, just drink the whiskey, and then you won't worry about the weeds.![]()
Me neitherI wish - not allowed![]()
Me neither![]()
Well, it's an example of survival of the fittest.It always surprises me how dandelions can manage to take root in places where nothing else wants to grow. If you wanted something else to grow there, it would probably wither and die. A squirt of Weedol will soon sort them out.
Rik
A weed, according to a gardening guru I once heard, is any plant growing where you don't want it.There is no definition of a weed,
