Ox Mountain Railway
Talking of insects, look what a magpie dropped into our garden
It's about 11/2-2" long. Quite harmless (I think), but it looks bloody fearsome
Is it a stag beetle? Edit; forgot to post the question!
A bit more work at tea time ....
Fixing the bent timbers....
The warp at the far end :banghead: Still, Cross pieces underneath (to support the track) might weell allow me to force it straight wid the aid of a cramp or two!
And, just to say that the bridge itself was built with a downhill gradient, and the decking also (doubling the fall)!
As can be see by the above picture, the bridge is still sagging in the middle (am I sagger maker bottom knocking?). Anyway, attempts to replace rotten timberwork at the far end of the bridge caused even more work! I considered rebuilding in aluminium but the cost was too much as I required at least 34 metres of 15x15 angle. Even in aluminium, the nearly 10ft span needed some steel to support everything so I've now bought some 40x40x3mm steel angle to support the wood. I cut the two pieces to exact length, dressed the ends with the angle grinder and a flat file and started giving them a coat of paint. The "outside" has now had two coats and the "inside" one. Once dry, I can turn the steel over again for painting.
Weather still good, so I might get to finish the painting!
I managed to get the steel angles in position underneath the bridge and mainly fastened in place. The end, where the new twisted timbers are, still needs to be sorted (different places to clamp, to draw the offending bits into linear conformity) - as does the replacement of damaged struts, etc.
Both pics taken after first piece of angle was fitted (didn't know if the weather would hold out). Evidence of more damaged bits of course, plus the offending ends of the new longitudanal timbers can still be seen at the far end of the bridge!
More work to follow (if fine).....
I decided to start work early (before the rain comes)! Managed to tame the errant wood using three clamps and then there was the odd drop of rain and dark skies. So I put the tools back in the shed, took a couple of pics and dodged the short shower ......
I have the cross levels to sort out yet, plus track supports. Then the partial rebuild will commence. Meanwhile, garden things to do ....
Started yesterday after cutting back a non-fruiting red currant bush (goats got a nice barrow load to eat)! Coffee calls now (well she said it was ready)! Its a hard life - even the sun has come out again. What excuses can I think of?
Did a little bit more this morning - made a two pair of support legs for the bridge .....
No the steel isn't bent - just the camera :D
So, now the bridge is fully supported by the steelwork, and the new timbers either side of the track are bolted to the steel, I can replace rotting timbers timbers without fear of the whole job lot dropping into the pond!
Yesterday I cleaned the tracks on the trailer layout - using wet wipes. I took a piccy of the used wipes ......
even though the rail heads looked clean to start with, it's obvious they were not!
Why you not have an LGB Track Cleaning Block?
Worked, yes, but killed every insect they came in contact with (and with DDT, humans too).
In many third world countries the ddt saved many lives that are now lost to malaria and other mosquito born diseases as well.
One more two edged sword..
Did you know that Ireland is classed as third world, because third world means non-aligned with USA or Russia, though people us it incorrectly, I think the term you are after is developing nations.
Po-taa-to Po-ta-to
I am old enough to remember the time before "developing nations" was a tem. :rolleyes:
Is malaria a problem in Ireland?:giggle:
Po-taa-to Po-ta-to
It could be if you brought it with you on returning from a holiday :D
Never given it a thought really!
Will be much easier to get you rail head nice n clean in the trailer for show running. Did a visit to an indoor railway with small locomotives only, track cleaning was with a bright boy (kitchen sponge thing) and rails never truly shiny and clean. LGB block would have done the job, I was going to take mine next time. But there never was a next time as the line was shortly after demolished during a move. Never again to re-appear.
I don't have any oxidisation problems with the trailer layout - the wet wipes remove any crud (as can be seen) that develops over a period of six hours continuous running. Out in the garden is a different thing!
