Can you be so kind to list all the hardware you selected & installed in your tender ? thank you
Of course, from left to right:
Left Blue PCB - My WiDCC board, see here:
WiDCC board - my take on a wireless DCC controller.
In a nutshell - allows control of a DCC decoder with radio control - either an iBUS/SBUS based system OR a nRF24 based system (of my own design).
Top - hidden up in the coal bunker is a 'stay alive' for the WiDCC board - a 22mF (22000uF) capacitor bank. This includes inrush protection via a passive diode / resistor arrangement.
Black PCB - Cytron MD13S motor board. Takes the DCC logic signal from the WiDCC board and amplifies it to the voltage and amperage required for the Decoder. DC power is fed from the WiDCC rectifier, and protected with a fuse.
Centre switch - Switches the decoder input between direct track (for programming / DCC running) / OFF / Wireless DCC. This has a small header board that connects all of the pickups, engine and tender, together. The engine pickup and motor wires are run via cables installed between engine and tender.
Right Blue PCB - ESU LokSound v5 L - my initial idea was to have a Loksound in the back and a Lokpilot in the front - this didn't work out. I have a LokSound v5 XL on the way to replace it - I feel two motors may be a bit much for a LokSound L.
There is also a small LokPilot FX installed in the engine, which drives the smoke unit, lights, couplers, etc, via a DCC signal send to the engine from the tender.
