Continuing on from the previous post, with ingenuity, common sense and the aid of a Multi Meter!, the EVO-S with a few ad hoc items, can imitate the EVO -X, save for the ITC/IR Interface which I have no use for.
As below, two Relays to reverse the EVO-S, useful for when the train cut opens the turnout, the turnout can be automatically switched back to the desired preferred position via a time value set on the Relay Module.
To trigger, either by the simple method of a Reed Switch, positioned at least in length of the longest train away from the turnout and activated by a magnet under the Loco.
Or as previously discussed and described further back in this thread, the use of a Massoth Train Detection Module in stand alone mode, this item is not Massoth dependent!
Of course if using the full blown Massoth Switch and Drive methodology, simple as falling of a log to operate.
Anyways things to do, Signals to make, shed load of OO gauge items to attend to, remainder of this month is fully booked, important date for your diaries if you reside in the North East, is the 28th July at Eric Upton's house in Scarborough regarding the future of the G Scale Society Area Group's.
Regardless of the outcome, a trip to Sheffield is on the cards, rapidly running out of will power and space!
