Oddly, the spare tender I have is Pennsylvania #210. Not 6 5 thousand.
Or as we say in UK a triangle. I did one for a test of the LGB 55080 DCC reverse loop unit but I was lazy and used a couple of isolating sections plus straights making the loop somewhat larger. Your loop will be tiny, are you using DCC with the module? If so it may be a bit chalenged with locomotives and any lighted stock.
The tininess is prototypical, because this is a tram layout. I won't use DCC, mainly DC via the overhead. Since two-rail DC will also be used I'm isolating one leg of the wye, or triangle.Your loop will be tiny, are you using DCC with the module? If so it may be a bit challenged with locomotives and any lighted stock.
Oh you can run into trouble with overhead 2 rail and triangles and common return. Fancy switching will be required.The tininess is prototypical, because this is a tram layout. I won't use DCC, mainly DC via the overhead. Since two-rail DC will also be used I'm isolating one leg of the wye, or triangle.
Thanks. I know all that, and am in the process of thinking it through.Oh you can run into trouble with overhead 2 rail and triangles and common return. Fancy switching will be required.
Ah, nothing too rare then. I was thinking maybe 5th century Ming.Hi, Jasper. The pots look similar to the counter-weights used on some pull-down light fittings in a bar in Luenen, Germany that I visit when I'm over there working. (I'm not working at the bar, but at our facility in the town!)
I was thinking on the same lines. You HAVE had them valued, haven't you, Jasper?Ah, nothing too rare then. I was thinking maybe 5th century Ming.
Of course. Valued at "Fungus Grade"You HAVE had them valued, haven't you, Jasper?
The wheel one end rides in the axle guards, this end the construction shown is to allow the wheel to wobble left n right for 3 point suspension. A view underneath now it is fitted, I had to cut some of the wood away on the side-frame to move the axle guards out a bit to allow sufficient space for the movement. Hope pics make things clearer, from side view subterfuge near impossible to see.dunnyrail
Can you tell more about this conversion? I get that one axle is held by a new c-shaped thing that pivots in the middle near the wagon floor, but what about the axle box assembly, I think you cut it off and are now re-attaching it, what's changed? Is this just to make the wheelset removable?
Nice what Gauge track and Scale are you using, be good to see more of your work.oh, am new here, but am going to love this thread ... have always been a bit of a voyeur into other's WIPs and workbenches...
ok, here's my 2c worth for today...brake shoes for my BR Class 06.....BTW the brakes are for show only...
first on in situ next to the sandbox...
...i can post more as I progress if anybody is interested...
