As mentioned previously, Father Christmas was kind enough to deliver a number of cast resin buildings for the Claptowte Railway, including a Kippo Models Station Building and Toilet Block. I have not previously had any experience of putting together resin building kits, so it was logical that I start with the smallest and simplest, this being the Toilet Block.
The Station Building and Toilet Block parts came wrapped together in a single parcel. The first thing to do was separate the parts, Kippo having helpfully marked most of the Toilet Block parts with TB in pencil. Once I had gathered the parts, I set about them with files and abrasive paper to clean up the various mouldings. When this was done, everything was given a good wash in soapy water to clean off any mould release agent.
Although the parcel contained a set of assembly instructions for the Station Building, there were none for the Toilet Block. I fired off an email to Kippo Models and received an almost immediate reply from Edward Williams of Kippo Models. It appears they do not include instructions with their smaller kits but he referred me to a tutorial video on Youtube, in which he was co-incidentally assembling a Toilet Block. There were two videos, one dealing with assembling and another dealing with painting. I found these both very useful and adaptable to my needs. I have included the links for anyone interested.
I assembled the main structure, as per Eddie's advice, using Gorilla Superglue to assemble and then worked some Unibond Repair Metal, similar to plastic padding, into the corner joins. I then attacked some of the roof slates to give the appearance of a few cracked/broken ones. The only part of the assembly that I am not certain about is the fitting of the facia boards to the end gables. This part of the assembly was missed in the video. I am not happy with the fit of these parts and will probably fabricate new ones from plasticard. This is the story so far, next everything will be off the the spray booth (old cardboard box) for a spraying with grey plastic primer.
