Not so much working on the bench, as working in the work room. I have at last got around to making a start on assembling the base boards for the Claptowte Railway. The first pic shows the frame of the first of a pair 1200 x 600 mm boards that will form the base, joining the two legs of the 'U' shaped layout, with one of the legs being the terminus, Gernise End, and the other, the storage sidings Phydell Yard. These boards, as well as accommodating the curve that will join the two legs, will also carry the sidings known as Goudes Sidings. These boards will be numbered 5 & 6.
The bare frame
The frame topped with 9mm plywood.
The boards will not be finished until I have filled the screw holes, sanded everything flush, added locating dowels and catches, oh and did I mention paint
The next pic shows the frame of the first of four 1500 x 825 mm boards. This board, to be number 7, will form the bottom right leg of the 'U' and will carry the the curve up to the throat of Phidell Yard at the start of board 8, also the ends of the sidings at Goudes Sidings, and, the ends of the loco stabling facilities at Phidell Yard.
Lots of work still to do, it's only taken me getting on for 30 years of modelling to get to this stage.
