Further progress on the turntable. The side frames include several angles, which makes applying clamping pressure virtually impossible. So glue was applied, the parts pressed together, and left to dry.
The truss rods were next, glued in place with epoxy, and the turnbuckles fixed in place with lo-melting point solder.
20241126_152759.jpgJust to show Fezwig Fezwig , I dug out the ex-County Donegal railcar: ta-daa!
However, there was a snag: length was fine, but width wasn't. So there was only one thing for it: saw the thing in half and fit a strip along the whole length...
Timber braces have been cut and glued in place. The next step is to fit a 40mm wide strip of 3mm ply into the deck. If it was good enough for the Morris Minor, it's OK for me...
View attachment 335353Just to show Fezwig Fezwig , I dug out the ex-County Donegal railcar: ta-daa!
PLY! on a Morris Minor! Ash dear boy, Ash:smirk: That's a shame, At least you found out now. perhaps you should have used a set of CDR locomotive frames:giggle:
