Nodrog1826
Professional Idiot
.....and so it begins.....My initiation into the dark art of chip installation.....
This is the way I have done it, its not THE way but the way I have chosen...
Firstly, pester Mark at GRO, for some parts advice, and having noted his suggestions, change your mind as to where to put the speaker, and as he has only one of the Blue power buffers left place an order, then await delivery.
So having stripped the loco down, to see where everything is going to fit, you may as well take the rods off and renew the traction tyre.
So the let the trials begin...Decided to go with the Massoth method posted in the fitting guides...
Fit the various parts, by modifying the internal cab roof for the speaker, solder lights and smoke unit connections to the various CT cables, as well as the power buffer, insulate the weight then fit chip, using sticky velcro tape, so you can get at the chip should the need arise.
Check its all working, on a bench test, and then reassemble, only to discover two things, the power buffer will not fit in the boiler, where you have seen someone else fit it, and that the smoke unit has stopped working.
So do a partial strip down to gain access to the smoke unit connections, check whilst crossing fingers, that I ain`t blown the smoke unit, which is ok, one to put down to sods law, re assemble loco, do another bench test, congratulate yourself on a job well done, (Well no one else will.) and admire your handy work.
Just need to get a Driver to fit into the cab, to help disguise where I had to install the power buffer, and Robert is my dads brother...
