A small update on the tramways that are currently being built. First, the Hagen tram 336 and its trailer 133 are 99% finished. only the couplings need to be adjusted. However, I can only do this on my friend's outdoor layout. The last work on this tram set was the rear view mirrors on the motor coach.
Above picture, headlighs, (warning) indicators, Lightings inside and number lights,
Bottom picture, changed direction showing now brake lowest ones and rear lights in the middle
The mirror is mounted.
Secondly: The water sprinling car 711 and its trailer 1724 have finally received the electrical wiring, so that the trailer has now also received its back and front lights. Later it looks like the green one. (Not mine)
Electric from ther motor tram to thr trailer vis front cable an couplingd. A seperate decoder in the tralier.
The motor tram 711 has also a rotating warn light on both sides of the roof.
Thirdly: The Vestische Conversted articulated four-axle tram ,has been wired and will receive its motor block at the end of January.
Wirr warr cables wiring - 12 wires.
The motor block will be ready at the end of January. To the right the trailing chassis with the three-point ball bearing mounted wheels,
How the motoblock is made. A friend of mine made it woth a CNC milling machine. He made four of those blocks three for his models and one for me.
