What have you been printing.
I printed off another negative. Works better with less depth in the mould. I sprayed the mould with wd40 before applying the concrete and it just slipped out when almost cured.
Are you putting any strengthening in as with the depth at size (9” square?) might be a little brittle. Perhaps some flayt anodised ally chicken wire?
Yep, or nylon mesh - garden plant covering for the use of ;);)
Concrete is strong in compression, but has no tensile strength worth talking of.
As a young, impressionable teenager just having done O levels, our physics master arranged two trips, one to Ewell Technical College where they showed us how they tested concrete for strength by crushing a cube - impressive. Then they took a concrete cylinder, laid it on its side and crushed it, and it split apart vertically at next to nothing - that was the tensile test.
At that time, I went on to do language A levels, and never had an inkling that I would spend a lifetime in the construction industry :nerd::nerd::nerd::nerd:
Observations after 2 weeks with a 3d printer.
Ok, there is a lot of information on the micro SD card, if you are brave enough to plug it into your PC. The slicing details , from the card, would not load onto my iMac, research suggests that it is an old version and it is better to download Cura from the internet, this I did and set it up to work with my Ender 3pro.
I bought a spare micro SD card to download files from 'Thingiverse' , my iMac does not recognise the blank card in the USB adapter provided with the printer, however, the card came with a standard adapter, which plugs into the slot on the iMac. I have, successfully downloaded a few bits from 'Thingiverse' moved the file into the slicer and saved it on the spare SD card, which when transferred to the printer, prints away merrily!
I ordered some black PLA filament from Amazon, which seems to work well, in fact I have just ordered a real of white, of the same type. Less than half the price of the roll that I ordered with the printer.
I, now feel confident to download items from 'Thingiverse' and print them, I seem to have got the bed level on the printer and my prints are good.
My next challenge, is to master a CAD drawing package but with the help of YouTube videos and the net, I hope to be able to archive something soon................watch this space!
Dave
There's so much to see.. You guys have been busy.. Wify says I'm getting obessesed with the printer.. We don't know what she means..
Hm that means she does not understand the effort involved with getting to grips with the tech, bit like trying to understand women really.
Hey all, this is my first post on the forum. This week printing its been in pieces to
Wow, looks very impressive, certainly a big piece of kit. Is it one of the Leek and Manifold tanks?
It isn’t a kit I’m afraid. It is a South Australian Railways F class I cannot claim the Stl file drawings as my own. However the chassis development is.
I am using a flash forge adventurer 3 to print with sunlu abs plastic. the printer has issues with layer adhesion but this print has came out okay.
It's a credit to you. Regardless!
Today it's dry out, so I'm fitting the sides to the bridge.. IMG_20200824_113731.jpg
Oh a nice loco and well printed be good to see it finished and a vid of it running pretty please.
Just finished printing the 60+ parts needed for the beam engine. Although there are 54 different parts, multiple copies are needed of some parts such as the linkages for the piston rod.
Also, the firmware on my cheapo printer includes a bug which prevents the z axis rising above 36mm. A flaming nuisance but not insurmountable as I simply chop the taller parts into pieces no taller than 35mm and will then glue them back together.
I could install a more recent version of the firmware if I could find a way to get the motherboard to communicate with my laptop. As it's Arduino based I might be able to find an alternative way of doing it. If the worst comes to the worst, a new motherboard (hopefully with bug free firmware) is only £20!
Rik
Now put all the bits together and, surprisingly enough, it works. The quality of the printing from my £80 printer isn't the best - particularly with taller parts, but with a bit of work I think it will look OK.
And what is more ....... it works!!
OK - it needs to be slowed down a bit. I've got one of those geared motors, but I need to modify the motor housing to take it.
Not bad for free ..... (apart from the cost of the plastic and the electric)
Rik
View attachment 272090View attachment 272091View attachment 272092
Rik
Excellent, and if you're going to be seeing it inside a building, then the detail's fine - can you not just reduce the voltage?
I'm already only feeding 1.2v to the motor from a rechargeable cell, so not got much to play with.
Rik
Rik
:oops::oops: and presumably you're running it as the original video you should us - shaft to wheel rim.
Smaller motor then - I've got a couple salvaged from camera lenses :tmi::tmi: if you're interested.
Rik
Excellent as ever Rik, I reckon the slight roughness from the printing process looks very like casted parts which in fact is what they will have been just machined around the working parts.
Yup! The easiest option as he also included a rig to hold the motor, battery and switch in the right position.
I'm just working on a Plan B - if that doesn't do the job then I might take you up on the offer...:)
Rik
